<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[RECALBOX 6.0 + RASPBERRY PI 3A+ :(]]></title><description><![CDATA[<p dir="auto">Bonjour à tous,<br />
Pourquoi le Raspberry PI 3A+ ne fait pas parti des modèles RPIs compatibles Recalbox 6.0 ?<br />
je confirme qu'il ne boot pas ou reste bloqué au boot. (Image Raspberry Pi 3 / 3 B+<br />
rpi3)</p>
<p dir="auto">Merci pour vos messages d'espoir <img src="https://forum.recalbox.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=qq7v1sdgudo" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" title=":)" alt="🙂" /></p>
]]></description><link>https://forum.recalbox.com/topic/17228/recalbox-6-0-raspberry-pi-3a</link><generator>RSS for Node</generator><lastBuildDate>Wed, 15 Apr 2026 09:57:37 GMT</lastBuildDate><atom:link href="https://forum.recalbox.com/topic/17228.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 14 Apr 2019 19:13:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to RECALBOX 6.0 + RASPBERRY PI 3A+ :( on Fri, 19 Apr 2019 17:00:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.recalbox.com/uid/2726">@piboy</a> yep oldschool method <img src="https://forum.recalbox.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=qq7v1sdgudo" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" title=":)" alt="🙂" /></p>
]]></description><link>https://forum.recalbox.com/post/124860</link><guid isPermaLink="true">https://forum.recalbox.com/post/124860</guid><dc:creator><![CDATA[ian57]]></dc:creator><pubDate>Fri, 19 Apr 2019 17:00:43 GMT</pubDate></item><item><title><![CDATA[Reply to RECALBOX 6.0 + RASPBERRY PI 3A+ :( on Fri, 19 Apr 2019 07:52:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.recalbox.com/uid/2245">@ian57</a><br />
Merci pour cette info <img src="https://forum.recalbox.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=qq7v1sdgudo" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" title=":)" alt="🙂" /><br />
Je testerai cela.<br />
Sous Retropie, cela fonctionne en compilant le driver  mk_arcarde_joystick et en assignant les pins que l'on souhaite utiliser mais c'est galère !</p>
<p dir="auto">Vive Recalbox ! Forsa</p>
]]></description><link>https://forum.recalbox.com/post/124754</link><guid isPermaLink="true">https://forum.recalbox.com/post/124754</guid><dc:creator><![CDATA[piboy]]></dc:creator><pubDate>Fri, 19 Apr 2019 07:52:20 GMT</pubDate></item><item><title><![CDATA[Reply to RECALBOX 6.0 + RASPBERRY PI 3A+ :( on Tue, 16 Apr 2019 14:42:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.recalbox.com/uid/2726">@piboy</a> "PS : Ce serait génial aussi de pouvoir allouer dynamiquement les numéros de PINs du RPI pour les touches de Joystick, mais c'est un autre sujet :)" ça  c'est fait dans la 6.0 avec les custom GPIO :</p>
<pre><code># ------------ D2 - GPIO Controllers ------------ #
## GPIO Controllers
controllers.gpio.enabled=0
controllers.gpio.args=map=1,2
## Custom mk_gpio arguments,
## map=5 gpio1=Y-,Y+,X-,X+,start,select,a,b,tr,y,x,tl,hk  for one controller,
## map=5 gpio1=pin1,pin2,pin3,.....,pin12,pin13
## map=5,6 gpio1=Y-,Y+,X-,X+,start,select,a,b,tr,y,x,tl,hk gpio2=Y-,Y+,X-,X+,start,select,a,b,tr,y,x,tl,hk for 2 (map=5,map=5,6)
## map=5,6 gpio1=gpiox,gpioy,gpioz,.....,gpiou,gpiov gpio2=gpiox,gpioy,gpioz,.....,gpiou,gpiov
# where gpiox,gpioy,gpioz ... are NOT pin numbers on the connector, BUT location gpio numbered as in
# https://www.raspberrypi-spy.co.uk/wp-content/uploads/2012/06/Raspberry-Pi-GPIO-Layout-Model-B-Plus-rotated-2700x900.png
## Set pin to -1 to disable it
# controllers.gpio.args=map=5,6 gpio=4,17,27,22,10,9,25,24,23,18,15,14,2 gpio2=11,5,6,13,19,26,21,20,16,12,7,8,3
## MCP configuration : GPIO and MCP can be used together. You can mix them.
## map=0x20,0x21 for 2 mcp23017 on i2c bus
#controllers.gpio.args=map=0x20,0x21,5,6 gpio=4,17,27,22,10,9,25,24,23,18,15,14,-1 gpio2=11,5,6,13,19,26,21,20,16,12,7,8,-1
</code></pre>
]]></description><link>https://forum.recalbox.com/post/124353</link><guid isPermaLink="true">https://forum.recalbox.com/post/124353</guid><dc:creator><![CDATA[ian57]]></dc:creator><pubDate>Tue, 16 Apr 2019 14:42:35 GMT</pubDate></item><item><title><![CDATA[Reply to RECALBOX 6.0 + RASPBERRY PI 3A+ :( on Tue, 16 Apr 2019 08:26:38 GMT]]></title><description><![CDATA[<p dir="auto">Bonjour et merci pour la réponse.</p>
<p dir="auto">Ceci dit, je ne cherche pas la grande performance , malgré les 512 Mo de RAM, je fais tourner à merveille la N64 et Sega 32X sous Retropie.<br />
Comme je réalise ce modèle de console portable <a href="https://www.elektronicaone.fr/super-pie-boy2/" rel="nofollow ugc">SPBO2</a>, j'ai besoin de réduire l'espace et le RPI 3A+ est parfait :).</p>
<p dir="auto">J'ai hâte de retrouver Recalbox sur mon RPI 3A+.</p>
<p dir="auto">PS : Ce serait génial aussi de pouvoir allouer dynamiquement les numéros de PINs du RPI pour les touches de Joystick, mais c'est un autre sujet <img src="https://forum.recalbox.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=qq7v1sdgudo" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" title=":)" alt="🙂" /></p>
]]></description><link>https://forum.recalbox.com/post/124293</link><guid isPermaLink="true">https://forum.recalbox.com/post/124293</guid><dc:creator><![CDATA[piboy]]></dc:creator><pubDate>Tue, 16 Apr 2019 08:26:38 GMT</pubDate></item><item><title><![CDATA[Reply to RECALBOX 6.0 + RASPBERRY PI 3A+ :( on Sun, 14 Apr 2019 19:32:56 GMT]]></title><description><![CDATA[<p dir="auto">Parceque nous devons remettre à jour quelques outil pour pouvoir rendre Recalbox compatible avec la 3A+.<br />
C'est dans le pipe ceci dit, il faut juste patienter un peu <img src="https://forum.recalbox.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=qq7v1sdgudo" class="not-responsive emoji emoji-android emoji--wink" title=";)" alt="😉" /></p>
<p dir="auto">Ceci dit attention avec le 3A+. Il est un peu plus petit (mais pas beaucoup), il a moins de connecteurs (à réserver pour des engins portables), mais il a surtout deux fois moins de ram que le 3B+. Et ça c'est un réel problème pour les émulateurs.<br />
On peut tout de suis oublier la PSP ou la DC sur cette board.<br />
On peut aussi oublier les thèmes autres que celui par défaut, et il faudra être plus que raisonnable sur la quantité de systèmes qu'on rendra disponibles sur ES!</p>
]]></description><link>https://forum.recalbox.com/post/124102</link><guid isPermaLink="true">https://forum.recalbox.com/post/124102</guid><dc:creator><![CDATA[Bkg2k]]></dc:creator><pubDate>Sun, 14 Apr 2019 19:32:56 GMT</pubDate></item></channel></rss>
