<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[hdmi laptop cutoff screen]]></title><description><![CDATA[<p dir="auto">Hi im new forgive me, I have usb stick with recal on it , i have my roms on a 1tb hdd and its connected to my acer laptop. I connect the laptop to my panasonic tv through hdmi and half the screen cuts off. I have looked at similar posts and tried as much as i could to my knowledge to get this fixed.  I dont know how to run command through linux if that is possible on a pc. please help and direct me i would greatly appreciate it.</p>
<p dir="auto">thank you</p>
]]></description><link>https://forum.recalbox.com/topic/16069/hdmi-laptop-cutoff-screen</link><generator>RSS for Node</generator><lastBuildDate>Wed, 17 Jun 2026 19:51:31 GMT</lastBuildDate><atom:link href="https://forum.recalbox.com/topic/16069.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 17 Dec 2018 19:14:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to hdmi laptop cutoff screen on Tue, 18 Dec 2018 03:46:02 GMT]]></title><description><![CDATA[<p dir="auto">So i got to the point where i needed to download the ftp clients i downloaded a couple such as filezilla and winSCP and I cant connect even after connecting wifi to recalbox. Im at a loss was trying to get this done for the holidays and play with family.</p>
<p dir="auto">Any help is greatly appreciated</p>
]]></description><link>https://forum.recalbox.com/post/115035</link><guid isPermaLink="true">https://forum.recalbox.com/post/115035</guid><dc:creator><![CDATA[bizmoan]]></dc:creator><pubDate>Tue, 18 Dec 2018 03:46:02 GMT</pubDate></item><item><title><![CDATA[Reply to hdmi laptop cutoff screen on Mon, 17 Dec 2018 23:30:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.recalbox.com/uid/31426">@bizmoan</a> you can not connect?<br />
if you want to reboot,<br />
reboot with the pc power button</p>
]]></description><link>https://forum.recalbox.com/post/115031</link><guid isPermaLink="true">https://forum.recalbox.com/post/115031</guid><dc:creator><![CDATA[strodown]]></dc:creator><pubDate>Mon, 17 Dec 2018 23:30:01 GMT</pubDate></item><item><title><![CDATA[Reply to hdmi laptop cutoff screen on Mon, 17 Dec 2018 23:14:02 GMT]]></title><description><![CDATA[<p dir="auto">thankyou im really having a hard time..how do i exit..nothing seems to be working correctly..so confused..</p>
]]></description><link>https://forum.recalbox.com/post/115030</link><guid isPermaLink="true">https://forum.recalbox.com/post/115030</guid><dc:creator><![CDATA[bizmoan]]></dc:creator><pubDate>Mon, 17 Dec 2018 23:14:02 GMT</pubDate></item><item><title><![CDATA[Reply to hdmi laptop cutoff screen on Mon, 17 Dec 2018 22:48:17 GMT]]></title><description><![CDATA[<p dir="auto">log:<code>root</code><br />
password:<code>recalboxroot</code></p>
]]></description><link>https://forum.recalbox.com/post/115028</link><guid isPermaLink="true">https://forum.recalbox.com/post/115028</guid><dc:creator><![CDATA[strodown]]></dc:creator><pubDate>Mon, 17 Dec 2018 22:48:17 GMT</pubDate></item><item><title><![CDATA[Reply to hdmi laptop cutoff screen on Mon, 17 Dec 2018 22:36:24 GMT]]></title><description><![CDATA[<p dir="auto">thank you for you reply its is asking me for a login and password. No idea which one im suppose to put.</p>
]]></description><link>https://forum.recalbox.com/post/115027</link><guid isPermaLink="true">https://forum.recalbox.com/post/115027</guid><dc:creator><![CDATA[bizmoan]]></dc:creator><pubDate>Mon, 17 Dec 2018 22:36:24 GMT</pubDate></item><item><title><![CDATA[Reply to hdmi laptop cutoff screen on Mon, 17 Dec 2018 21:50:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.recalbox.com/uid/31426">@bizmoan</a> hello to switch to cmd mode starts your recalbox then you press <code> F4</code> the menu recalbox will disappear then you do <code> ctrl + alt + F2</code> you log and you can enter commands for your case <code>xrandr</code> will be useful<br />
little tutorial :<code>https://github.com/recalbox/recalbox-os/wiki/Change-display-resolution-on-x86---x86_64</code></p>
]]></description><link>https://forum.recalbox.com/post/115024</link><guid isPermaLink="true">https://forum.recalbox.com/post/115024</guid><dc:creator><![CDATA[strodown]]></dc:creator><pubDate>Mon, 17 Dec 2018 21:50:19 GMT</pubDate></item></channel></rss>
