Next Pixel theme
  • Creator
    Team
    @mYSt great work! looks good even if 4/3 compatibility is not at best ;)
  • Version 0.8.1
    Just released a new version to add 4:3 support (and 16:10), i couldn't leave it as is when i saw @ian57 picture :), also fixed somme issues with 720p screens.
    Please read carefully download instructions for 16:10 users and users having memory issues with Raspberry Pi, when switching to 720p package on 1080p screen, i added instructions to force recalbox to run at 720p as weel as it will greatly improve image quality.
    Changelog:
    • Add 4/3 screens support
    • Add 16/10 screens support
    • Add ports support (using cavestory game theme and prboom game theme as alternative)
    • Fix layout on 720p screens
    • Fix wheel scrolling direction
    @ian57 try 4:3 version and now you can tell me it didn't look great at all ;)
  • Creator
    Team
    @mYSt ok, i will make a test ASAP. Thanks for the job.
  • Very exciting changes in last releases, I'm following development of this theme continuously :)
    Unfortunately, due to a lack of time, I currently can't install new version. Looking forward to final new RB version, then I'll go for install of latest Next Pixel version too.
    Also curious about your suggestion switching Pi to 720p mode, can't wait to try :)
    Thanks again for your work!
  • Bonjour à tous,
    Etant équipée d'un RPI 3B+, je suis actuellement sur la dernière version Beta de Recalbox (2019.02.24).
    Après avoir flashé ma carte SD SanDisk avec la cette version, j'ai remis le thème Next Pixel dans le dossier themes.
    Cependant, après avoir sélectionné le thème Next Pixel dans les menus de Recalbox, l'affichage ne se fait pas correctement.
    J'ai un fond noir avec uniquement le nom des consoles sur un bandeau.
    J'aimerai savoir s'il y a un éventuel problème de compatibilité entre la dernière version de Recalbox et ce thème et si quelqu'un a eu ce souci (avec la même configuration que la mienne).
    Merci pour vos retours.
    Hello everyone,
    Being equipped with a RPI 3B +, I am currently on the last Beta version of Recalbox (2019.02.24).
    After flashing my SanDisk SD card with this version, I put the Next Pixel theme in the themes folder.
    However, after selecting the Next Pixel theme in the Recalbox menus, the display is not done correctly.
    I have a black background with only the name of the consoles on a banner.
    I would like to know if there is a possible problem of compatibility between the last version of Recalbox and this theme and if someone had this problem (with the same configuration as mine).
    Thank you for your feedback.
  • @matth23
    Quel version as tu téléchargé (lien du zip)?
    Quel system view tu utilises (horizontal/vertical)?
    ça le fait aussi sur la liste des jeux?
    Si tu navigues dans les dossiers system du theme les fichiers background, background_legacy et background_wheel sont ils présents?
  • @mYSt
    J'ai utilisé le lien : https://github.com/SamYStudiO/es-next-pixel/archive/1080p.zip
    De base, le thème était en horizontal.
    Oui ça le fait aussi pour la liste de jeux.
    Pour les dossiers system, je vérifie ça ce soir. J'y ajouterai également une photo du rendu.
  • @matth23 Essayes de réinstaller complètement je vois pas trop, normalement le thème à la vue verticale par défaut donc bizarre que tu es eu l'horizontal, peut être tu as mélanger 2 versions.
  • @mYSt
    J'ai trouvé la solution, qui était finalement toute bête et surement logique.
    J'ai installé la version 720p du thème, aucun soucis, il fonctionne très bien.
    Merci quand même.
  • @mYSt Je voulais également te féliciter pour le travail fait sur ce thème qui est excellent !
    Après si jamais tu as besoin d'informations concernant la non-compatibilité du thème en 1080p avec ma configuration, n'hésites pas.
  • Moderator
    Moderator
    Team
    il est possible que le nombre de systèmes soient responsable d'une saturation avec un thème 1080p
    ON LE REPETE SOUVENT 720p conseillé....
  • @acris Je n'avais "que" 7 systèmes et le dossier favoris.
    Mais bon problème réglé avec le 720p.
  • Moderator
    Moderator
    Team
    @matth23 said in Next Pixel theme:
    Hmmm etrange dans ce cas possible qu un fichier soit corrimpu dans larchive...
  • @acris @Matth23 oui en effet il vaut mieux utiliser la version 720p sur un raspberry, par contre un écran noir est signe d'un problème de chargement de l'image (image non trouvée) et un écran blanc un problème de mémoire. A priori là c'est donc un pb d'image non trouvé et je serais curieux de savoir si d'autres ont le pb car je n'arrive pas à le reproduire.
  • @mYSt @acris Je peux envoyer une photo du rendu, ainsi que des captures d'écran de ce qu'il se trouve dans les fichiers s'il faut.
    De quels éléments auriez-vous besoin ?
  • @matth23 Si tu as encore le zip tu peux me le partager?
  • @myst J'ai supprimé le zip, mais je l'ai dossier (dezipé) que j'ai mis dans le dossier themes sur ma carte SD. Je m'en occupe ce soir.
  • @matth23 merci beaucoup pour le zip, j'ai effectivement eu le pb après installation de ton zip, je poste ici la solution qui peut servir à d'autres.
    Le pb je pense est que tu as du dézipper en utilisant la fonction extraire vers le dossier "es-next-pixel-1080p" alors que le zip possède déjà un dossier de ce nom. Du coup le thème après installation se retrouve dans .emulationstation\themes\es-next-pixel-1080p\es-next-pixel-1080p au lieu de .emulationstation\themes\es-next-pixel-1080p. Et avec ce chemin emulation station ne trouve pas les fichiers du theme.
    Du coup si tu utilises 10 systems ou moins tu peux tenter d’utiliser le theme 1080p sur un raspberry 3 pour tenter d'améliorer la qualité des images, sinon il y a mon astuce pour forcer emulation station en 720p ce qui améliore aussi la qualité des images sur un ecran 1080p+ avec le theme en 720p.
  • #teasing
    new gamelist view, using different color and layout settings
  • This looks fantastic! 😍
Join us on :
238
