<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ODROID XU4 TO HDMI-VGA 1280X1024]]></title><description><![CDATA[<p dir="auto">Hello I went from raspberry to odroid xu4<br />
And the impossible to run my vga screen. ..4 / 3 do you have an idea or solution c for a bartop it is planned for a 19in 4/3<br />
Thank you in advance</p>
<p dir="auto">Ps no signal l odroid does not even start I go to hdmi on another screen and it starts 1980x1020<br />
Have a headache</p>
]]></description><link>https://forum.recalbox.com/topic/14352/odroid-xu4-to-hdmi-vga-1280x1024</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Apr 2026 08:37:15 GMT</lastBuildDate><atom:link href="https://forum.recalbox.com/topic/14352.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 04 Jun 2018 07:12:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ODROID XU4 TO HDMI-VGA 1280X1024 on Thu, 28 Jun 2018 08:22:19 GMT]]></title><description><![CDATA[<p dir="auto">Je ai une nouvelle piste<br />
Sur YouTube il parle de écran lcd<br />
Ou il faut mettre à jour les drivers et c'est sur ogst<br />
Ensuite le reconfigurer ...</p>
]]></description><link>https://forum.recalbox.com/post/104351</link><guid isPermaLink="true">https://forum.recalbox.com/post/104351</guid><dc:creator><![CDATA[peche]]></dc:creator><pubDate>Thu, 28 Jun 2018 08:22:19 GMT</pubDate></item><item><title><![CDATA[Reply to ODROID XU4 TO HDMI-VGA 1280X1024 on Wed, 13 Jun 2018 21:07:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.recalbox.com/uid/24101">@gnubit</a>  thank you<br />
but don't work ;-(</p>
]]></description><link>https://forum.recalbox.com/post/103549</link><guid isPermaLink="true">https://forum.recalbox.com/post/103549</guid><dc:creator><![CDATA[peche]]></dc:creator><pubDate>Wed, 13 Jun 2018 21:07:41 GMT</pubDate></item><item><title><![CDATA[Reply to ODROID XU4 TO HDMI-VGA 1280X1024 on Wed, 13 Jun 2018 20:52:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.recalbox.com/uid/1056">@substring</a><br />
hello I went to a computer store<br />
to test my odroid<br />
<a href="http://www.eu.diigiit.com/fr/odroid-xu4q" rel="nofollow ugc">http://www.eu.diigiit.com/fr/odroid-xu4q</a></p>
<p dir="auto">it does not start on any screen PC against it starts on the tv with hdmi</p>
<p dir="auto">I modified the resolsution<br />
and I have the correct resolution that appears after the line choice that appears and<br />
for my pc screen I had chosen that the</p>
<h1>1280x1024 with data using generic information</h1>
<p dir="auto">setenv videoconfig "drm_kms_helper.edid_firmware = edid / 1280x1024.bin"</p>
<p dir="auto">on the other hand the screen of pc in the shop displays no signal: 0000x0000 / 00hrz</p>
<p dir="auto">I test another odroid the one with the fan<br />
<a href="https://www.francerobotique.com/hardkernel/570-odroid-xu4-art0570-hardkernelpoids-60g-dimensions-82-x-58-x-22-mm-alimentation-5v-4a-connecteur-gpio-ram-" rel="nofollow ugc">https://www.francerobotique.com/hardkernel/570-odroid-xu4-art0570-hardkernelpoids-60g-dimensions-82-x-58-x-22-mm-alimentation-5v-4a-connecteur-gpio-ram-</a> 2-go-LPDDR3-pop-process.html</p>
<p dir="auto">and it works why it does not work? or only on tv<br />
<p dir="auto">i need help thanks in advance</p>
]]></description><link>https://forum.recalbox.com/post/103548</link><guid isPermaLink="true">https://forum.recalbox.com/post/103548</guid><dc:creator><![CDATA[peche]]></dc:creator><pubDate>Wed, 13 Jun 2018 20:52:35 GMT</pubDate></item><item><title><![CDATA[Reply to ODROID XU4 TO HDMI-VGA 1280X1024 on Tue, 12 Jun 2018 19:29:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.recalbox.com/uid/1056">@substring</a> thank you but nothing<br />
i will change the adaptateur hdmi / vga<br />
or i buy a new screen with hdmi</p>
]]></description><link>https://forum.recalbox.com/post/103453</link><guid isPermaLink="true">https://forum.recalbox.com/post/103453</guid><dc:creator><![CDATA[peche]]></dc:creator><pubDate>Tue, 12 Jun 2018 19:29:07 GMT</pubDate></item><item><title><![CDATA[Reply to ODROID XU4 TO HDMI-VGA 1280X1024 on Sun, 10 Jun 2018 08:51:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.recalbox.com/uid/25931">@peche</a> first of all, learn to paste such code between triple back ticks blocks. The  result is supposed to look like :</p>
<pre><code>nice code block
</code></pre>
<p dir="auto">which you'd write as :<br />
```<br />
nice code block<br />
```<br />
(you can copy this in your answer and replace the text of course)</p>
<p dir="auto">Now, something is weird, because your boot.ini is supposed to looke like <a href="https://gitlab.com/recalbox/recalbox/blob/master/board/recalbox/xu4/boot.ini" rel="nofollow ugc">this</a>. So you'd just have to add a <code>#</code> in front of the current video mode and remove a <code>#</code> in front of the mode you wish to use</p>
]]></description><link>https://forum.recalbox.com/post/103272</link><guid isPermaLink="true">https://forum.recalbox.com/post/103272</guid><dc:creator><![CDATA[Substring]]></dc:creator><pubDate>Sun, 10 Jun 2018 08:51:20 GMT</pubDate></item><item><title><![CDATA[Reply to ODROID XU4 TO HDMI-VGA 1280X1024 on Sat, 09 Jun 2018 07:22:25 GMT]]></title><description><![CDATA[<p dir="auto">hello i test but nothing</p>
<p dir="auto">i change a lot value to ligne MODIFIE</p>
<p dir="auto">but nothing the screen work on hdmi but no work on adaptater hdmi-vga :</p>
<p dir="auto">if you have some idea</p>
<p dir="auto">great</p>
<p dir="auto">thank you to advance</p>
<p dir="auto">ODROIDXU-UBOOT-CONFIG</p>
<h1>U-Boot Parameters (DO NOT MODIFY)</h1>
<p dir="auto">setenv version 3.10<br />
setenv zimage zImage<br />
setenv fdtbin exynos5422-odroidxu3.dtb</p>
<h1>--- Screen Configuration for HDMI ---</h1>
<h1>---------------------------------------</h1>
<h1>Uncomment only ONE line! Leave all commented for automatic selection.</h1>
<h1>Uncomment only the setenv line!</h1>
<h1>ODROID-VU forced resolution</h1>
<h1>setenv videoconfig "video=HDMI-A-1:1280x1024" MODIFIE</h1>
<h1>-----------------------------------------------</h1>
<h1>ODROID-VU forced EDID</h1>
<h1>setenv videoconfig "drm_kms_helper.edid_firmware=edid/1280x10240.bin"</h1>
<h1>1280x1024 with monitor provided EDID information</h1>
<p dir="auto">setenv videoconfig "drm_kms_helper.edid_firmware=edid/1280x1024.bin</p>
<h1>1280x1024 without monitor data using generic information</h1>
<h1>setenv videoconfig "drm_kms_helper.edid_firmware=edid/1280x1024.bin"</h1>
<h1>--- HDMI / DVI Mode Selection ---</h1>
<h1>------------------------------------------</h1>
<h1>- HDMI Mode</h1>
<p dir="auto">setenv vout "dvi" MODIFIE</p>
<h1>- DVI Mode (disables sound over HDMI as per DVI compat)</h1>
<h1>setenv vout "dvi"</h1>
<h1>--- CPU Governor Setup ---</h1>
<h1>Uncomment only one line. New governor is set after 90secs after boot.</h1>
<h1>- Performance (Keep all the CPU's at Maximum frequency)</h1>
<p dir="auto">setenv governor "performance"</p>
<h1>- Ondemand</h1>
<h1>setenv governor "ondemand"</h1>
<h1>- Interactive (Pretty much just like ondemand with more possible customization via sysfs.)</h1>
<h1>setenv governor "interactive"</h1>
<h1>- Conservative (Like ondemand, but do the frequency transitions more slowly, great for battery powered applications)</h1>
<h1>setenv governor "conservative"</h1>
<h1>- Powersave (Keeps the CPU's to the lowest possible temps)</h1>
<h1>setenv governor "powersave"</h1>
<h1>--- HDMI CEC Configuration ---</h1>
<p dir="auto">setenv cecenable "true" MODIFIE</p>
<h1>false or true</h1>
<h1>set to true to enable HDMI CEC</h1>
<p dir="auto">#------------------------------------------------------------------------------</p>
<h1></h1>
<h1>HDMI Hot Plug detection</h1>
<h1></h1>
<h1></h1>
<h1>Forces the HDMI subsystem to ignore the check if the cable is connected or</h1>
<h1>not.</h1>
<h1>false : disable the detection and force it as connected.</h1>
<h1>true : let cable, board and monitor decide the connection status.</h1>
<h1></h1>
<p dir="auto">default: false MODIFIE</p>
<h1></h1>
<p dir="auto">#------------------------------------------------------------------------------<br />
setenv HPD "false"<br />
setenv hdmi_phy_control "HPD=${HPD}  vout=${vout}"</p>
<p dir="auto">setenv zimage_addr_r 0x40008000<br />
setenv fdtbin_addr_r 0x44000000</p>
<p dir="auto">setenv fdt_high "0xffffffff"</p>
<h1>Default boot argument</h1>
<p dir="auto">setenv bootrootfs "root=/dev/mmcblk0p2 rootwait ro"<br />
setenv console "console=ttySAC2,115200n8 consoleblank=0 vt.global_cursor_default=0"</p>
<h1>boot commands</h1>
<p dir="auto">fatload mmc 0:1 ${zimage_addr_r} ${zimage}<br />
fatload mmc 0:1 ${fdtbin_addr_r} ${fdtbin}</p>
<p dir="auto">fdt addr 0x44000000<br />
if test "${cecenable}" = "false"; then fdt rm /cec@101B0000; fi</p>
<p dir="auto">setenv bootargs "${bootrootfs} ${console} governor=${governor} ${videoconfig} ${hdmi_phy_control}"</p>
<p dir="auto">bootz ${zimage_addr_r} - ${fdtbin_addr_r}</p>
]]></description><link>https://forum.recalbox.com/post/103207</link><guid isPermaLink="true">https://forum.recalbox.com/post/103207</guid><dc:creator><![CDATA[peche]]></dc:creator><pubDate>Sat, 09 Jun 2018 07:22:25 GMT</pubDate></item><item><title><![CDATA[Reply to ODROID XU4 TO HDMI-VGA 1280X1024 on Thu, 07 Jun 2018 11:10:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.recalbox.com/uid/25931">@peche</a>  take a look here:</p>
<p dir="auto"><a href="https://pastebin.com/aMU3mkss" rel="nofollow ugc">https://pastebin.com/aMU3mkss</a>  (it`s the /BOOT/boot.ini  file)</p>
<p dir="auto">It <em><strong>should</strong></em> work ( I downloaded the xu4 image and edited the file, but I don`t have the hardware to test it on.)</p>
<p dir="auto">what I changed:</p>
<p dir="auto">I commented out:<br />
setenv videoconfig "video=HDMI-A-1:1920x1080@60"</p>
<p dir="auto">and added in it`s place:<br />
setenv videoconfig "drm_kms_helper.edid_firmware=edid/1280x1024.bin"</p>
<p dir="auto">I also commented out:<br />
setenv vout "hdmi"</p>
setenv vout "dvi"</p>
<p dir="auto">Hoping this might help <img src="https://forum.recalbox.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=qq7v1sdgudo" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" title=":)" alt="🙂" /></p>
]]></description><link>https://forum.recalbox.com/post/103086</link><guid isPermaLink="true">https://forum.recalbox.com/post/103086</guid><dc:creator><![CDATA[gnubit]]></dc:creator><pubDate>Thu, 07 Jun 2018 11:10:29 GMT</pubDate></item><item><title><![CDATA[Reply to ODROID XU4 TO HDMI-VGA 1280X1024 on Wed, 06 Jun 2018 17:44:52 GMT]]></title><description><![CDATA[<p dir="auto">I don t find on odroid boot/config. Text</p>
<p dir="auto">Where is it ?</p>
<p dir="auto">And you have the file ?</p>
]]></description><link>https://forum.recalbox.com/post/103050</link><guid isPermaLink="true">https://forum.recalbox.com/post/103050</guid><dc:creator><![CDATA[peche]]></dc:creator><pubDate>Wed, 06 Jun 2018 17:44:52 GMT</pubDate></item><item><title><![CDATA[Reply to ODROID XU4 TO HDMI-VGA 1280X1024 on Wed, 06 Jun 2018 07:43:22 GMT]]></title><description><![CDATA[<p dir="auto">This is my boot. Ini</p>
<h1>setenv videoconfig "video=HDMI-A-1:1280x1024"</h1>
<h1>1920x1080 (1080P) with monitor provided EDID information. (1080p-edid)</h1>
<p dir="auto">#setenv videoconfig "video=HDMI-A-1:1920x1080@60"</p>
<p dir="auto">#1920x1080 20x1080 (1080P) without monitor data using generic information (1080p-noedid)</p>
<h1>setenv videoconfig "drm_kms_helper.edid_firmware=edid/1920x1080.bin"</h1>
<h1>1920x1080 50hz (1080P) with monitor provided EDID information. (1080p 50hz-edid)</h1>
<h1>setenv videoconfig "video=HDMI-A-1:1920x1080@50"</h1>
<p dir="auto">setenv videoconfig "drm_kms_helper.edid_firmware=edid/1280x1024.bin"</p>
<p dir="auto">setenv vout "hdmi"</p>
<h1>setenv vout "vga"</h1>
<h1>- Ondemand</h1>
<p dir="auto">setenv cecenable "false" # false or true</p>
<h1></h1>
<h1></h1>
<h1></h1>
<h1>not.</h1>
<h1></h1>
<h1>default: false</h1>
<h1></h1>
]]></description><link>https://forum.recalbox.com/post/103029</link><guid isPermaLink="true">https://forum.recalbox.com/post/103029</guid><dc:creator><![CDATA[peche]]></dc:creator><pubDate>Wed, 06 Jun 2018 07:43:22 GMT</pubDate></item><item><title><![CDATA[Reply to ODROID XU4 TO HDMI-VGA 1280X1024 on Wed, 06 Jun 2018 07:28:59 GMT]]></title><description><![CDATA[<p dir="auto">Yes i modifie my boot.ini</p>
<p dir="auto">And I blocked signal hdmi video out 1280x1024</p>
<p dir="auto">my screen has no output hdmi and when i put the adapter hdmi / vga the signal does not come out</p>
]]></description><link>https://forum.recalbox.com/post/103027</link><guid isPermaLink="true">https://forum.recalbox.com/post/103027</guid><dc:creator><![CDATA[peche]]></dc:creator><pubDate>Wed, 06 Jun 2018 07:28:59 GMT</pubDate></item><item><title><![CDATA[Reply to ODROID XU4 TO HDMI-VGA 1280X1024 on Tue, 05 Jun 2018 06:20:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.recalbox.com/uid/25931">@peche</a> oh well, agyerall it's in /boot/boot.ini, you should uncomment the right edid</p>
]]></description><link>https://forum.recalbox.com/post/102970</link><guid isPermaLink="true">https://forum.recalbox.com/post/102970</guid><dc:creator><![CDATA[Substring]]></dc:creator><pubDate>Tue, 05 Jun 2018 06:20:21 GMT</pubDate></item><item><title><![CDATA[Reply to ODROID XU4 TO HDMI-VGA 1280X1024 on Tue, 05 Jun 2018 04:49:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.recalbox.com/uid/1056">@substring</a> Oops! my apologies. Link to XU4:</p>
<p dir="auto"><a href="https://wiki.odroid.com/odroid-xu4/troubleshooting/how_to_change_resolution" rel="nofollow ugc">https://wiki.odroid.com/odroid-xu4/troubleshooting/how_to_change_resolution</a></p>
]]></description><link>https://forum.recalbox.com/post/102969</link><guid isPermaLink="true">https://forum.recalbox.com/post/102969</guid><dc:creator><![CDATA[gnubit]]></dc:creator><pubDate>Tue, 05 Jun 2018 04:49:24 GMT</pubDate></item><item><title><![CDATA[Reply to ODROID XU4 TO HDMI-VGA 1280X1024 on Mon, 04 Jun 2018 14:09:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.recalbox.com/uid/24101">@gnubit</a> you've quoted the c2 documentation, not the xu4 <img src="https://forum.recalbox.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=qq7v1sdgudo" class="not-responsive emoji emoji-android emoji--wink" title=";)" alt="😉" /></p>
]]></description><link>https://forum.recalbox.com/post/102931</link><guid isPermaLink="true">https://forum.recalbox.com/post/102931</guid><dc:creator><![CDATA[Substring]]></dc:creator><pubDate>Mon, 04 Jun 2018 14:09:14 GMT</pubDate></item><item><title><![CDATA[Reply to ODROID XU4 TO HDMI-VGA 1280X1024 on Mon, 04 Jun 2018 12:34:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.recalbox.com/uid/25931">@peche</a> ordriod wiki might help</p>
<p dir="auto"><a href="https://wiki.odroid.com/odroid-c2/application_note/software/auto_detect_display" rel="nofollow ugc">https://wiki.odroid.com/odroid-c2/application_note/software/auto_detect_display</a></p>
]]></description><link>https://forum.recalbox.com/post/102922</link><guid isPermaLink="true">https://forum.recalbox.com/post/102922</guid><dc:creator><![CDATA[gnubit]]></dc:creator><pubDate>Mon, 04 Jun 2018 12:34:25 GMT</pubDate></item><item><title><![CDATA[Reply to ODROID XU4 TO HDMI-VGA 1280X1024 on Mon, 04 Jun 2018 12:26:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.recalbox.com/uid/25931">@peche</a> read the documentation tu know what videomode means</p>
<p dir="auto">Can't tell what you need, don't have the resources at hand to answer you right now</p>
]]></description><link>https://forum.recalbox.com/post/102921</link><guid isPermaLink="true">https://forum.recalbox.com/post/102921</guid><dc:creator><![CDATA[Substring]]></dc:creator><pubDate>Mon, 04 Jun 2018 12:26:38 GMT</pubDate></item><item><title><![CDATA[Reply to ODROID XU4 TO HDMI-VGA 1280X1024 on Mon, 04 Jun 2018 12:24:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.recalbox.com/uid/1056">@substring</a><br />
I test this by ssh in</p>
<p dir="auto">recalbox.conf</p>
<p dir="auto">global.videomode=default</p>
<p dir="auto">But no working</p>
<p dir="auto">What i do in boot/boot.ini ?</p>
]]></description><link>https://forum.recalbox.com/post/102915</link><guid isPermaLink="true">https://forum.recalbox.com/post/102915</guid><dc:creator><![CDATA[peche]]></dc:creator><pubDate>Mon, 04 Jun 2018 12:24:14 GMT</pubDate></item><item><title><![CDATA[Reply to ODROID XU4 TO HDMI-VGA 1280X1024 on Mon, 04 Jun 2018 10:58:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.recalbox.com/uid/25931">@peche</a> i guess it does start but it's not setting the right resolution. The XU4 lacks HDMI EDID autodetection and scale the output. You'd need to edit The /boot/boot.ini</p>
]]></description><link>https://forum.recalbox.com/post/102904</link><guid isPermaLink="true">https://forum.recalbox.com/post/102904</guid><dc:creator><![CDATA[Substring]]></dc:creator><pubDate>Mon, 04 Jun 2018 10:58:02 GMT</pubDate></item></channel></rss>
