Raspberry Pi 4
The Recalbox Team.
[Theme] Clean Retro
  • Themer
    We’re proud to present you our new Clean Retro theme. It’s been a long time we’ve wanted to make a clean theme so you could browse your collection in style! With the new theme customizer functionality, you can now choose between 5 different system views. Choose the help menu icons depending on the controller you’re using. Choose the system logos according to your country. Beautiful splash screen intro video is included. Non distractive overlays for all systems are included. A custom system list that organize all your systems is included. A custom mix image to scrape your games in high definition. New audio tracks have been added. We also remastered all audio tracks to have consistent audio level between system change. The theme is also fully compatible with any screens like CRT and smaller screens.
    text alternatif
    text alternatif
    text alternatif
    text alternatif
    text alternatif
    Mix image for scraping in UXS and gamelist view
    text alternatif
    text alternatif
    text alternatif
    text alternatif
    text alternatif
    text alternatif
    text alternatif
    text alternatif
    text alternatif
    text alternatif
    text alternatif
    text alternatif
    text alternatif
    text alternatif
    Menu match the theme design
    text alternatif
    Changelog
    V1.2
    • Added USA controller for Atari 7800
    • Added Japan system for Master System
    • Updated SVG "console" and/or "consolegame.svg" for 15 systems
    • Updated "icon_empty.svg" and "icon_filled.svg" for Amiga/Neogeo
    • Removed "game.svg" files
    V1.1
    • Fix game list view when there are roms but no "gamelist.xml" file
    V1.0
    • Added 5 system views
    • Added custom system logos
    • Added box art backgrounds from "cleanbg" theme
    • Added splash screen intro video
    • Added custom mix image for scraping with UXS
    • Added custom system list (Arcade, Consoles, Computers, Handhelds, Ports, Other)
    • Added generic crt classic overlay for older systems
    • Added generic crt flat overlay for newer systems
    • Added generic arcade overlay for Arcade system
    • Added per system overlay for each handhelds
    • Added per game overlay for Vectrex games
    • Added per system backgrounds
    • Added per system music tracks
    • Added compatibility for CRT and small screens
    • Modified various xml files from original theme
    Credits
    • Clean Retro - FreemanQC
    • Backgrounds - Niglurion
    • Original Theme - Recalbox
    this theme is compatible with the latest version of RB on Odroid XU4 only.
    DOWNLOAD LINK
  • @FreemanQC Really nice theme 🙂
  • i download and try after
  • @freemanqc on a posé une license sur les thèmes recalbox, il faudra la preciser Cf https://gitlab.com/recalbox/recalbox-themes
    Je te remercie de la lire et de la respecter. Dans les grandes lignes : réutilisable sans modification, en citant les auteurs, utilisation commerciale interdite
  • Themer
    @substring Allo! J'ai inclus la license d'origine dans mon readme.txt et j'ai bien lu le passage suivant
    Summary of the license below:
    ALLOWED: - Share and duplicate as it is
    - Edit, alter, change it
    REQUIREMENTS: - Attribution, give credit to the creator
    - Indicate changes to it
    - Publish the changes under the same license
    PROHIBITED: - Commercial distribution
    C'est donc permis de modifier le thème.
    Je ne fais pas de distribution commerciale.
    J'ai cité dans les crédits "Original Theme - Recalbox Team".
    Je ne comprend pas trop ce que j'ai loupé.
    Merci.
  • @freemanqc Jolie thème simple, basique 🙂
    Petite question car j'utilise également UXS, ou as-tu trouvé ces mix ?
  • Themer
    @toto421 Pour ceux la je pense que ce sont des styles de scrap perso adapté de FOOLSCREN , mais tu peux avoir le même style de rendu avec les MIX de scrap " FoolScreen " via le logiciel Universal XML Scraper V2.
  • Themer
    @mikozzz said in [Theme] Clean Retro:
    Absolument pas... on ne peut pas utiliser les mix Foolscreen dans d'autres thèmes comme le mien! J'ai fait mes propres mix pour chaque système. J'ai seulement prit le code et la borne d'arcade de Foolscreen pour l'arcade. Cependant j'ai du modifié beaucoup de trucs pour l'adapter.
  • @freemanqc Tu n'as pas lu la license : Creative Commons Attribution-NonCommercial-NoDerivs 4.0 License CC BY-NC-ND
    En aucun cas tu ne peux modifier ce qui provient de recalbox-next. Donc c'est :
    Tu es en CC-BY-NC-SA, nous sommes en CC BY-NC-ND. Tu ne peux pas modifier la license de ce qui provient de recalbox-next.
  • Themer
    @substring Excuse moi, mais c'est écrit le contraire dans le fichier de license du thème recalbox-next. Recalbox c'est open source et vous utiliser des logos licencié. Légalement j'ai le droit de prendre un thème et de le modifier tant et aussi longtemps que mon thème reste sous la même license et open source.
    https://gitlab.com/recalbox/recalbox-themes/tree/master/themes/recalbox-next
  • @freemanqc Encore un qui confond open source, libre, GPL et toute la clique derrière ...
    Les logos licensiés ? Ce qui veut dire que toi tu as tout droit dessus ? Non non non, faut pas déconner là.
    Mais va pour CC-BY-NC-SA.
  • Themer
    @substring Désolé je ne suis pas un professionnel des license mais peu importe si on oublie fait que j'ai mentionné les logos je te dirais que c'est tout simplement écrit sur votre gitlab que j'ai le droit. Explique moi ce que j'ai fait et que je n'ai pas le droit de faire exactement. Ton intervention n'est pas claire et je ne comprend pas. Merci.
  • @freemanqc va pour CC-BY-NC-SA, on s'en tient là.
  • @substring I am confused by the licensing too. Are you saying that the Recalbox-Next theme may not be modified at all or just that if a theme is a modification of Recalbox-Next you must use the same licensing terms and credit the original author(s)?
  • @freemanqc dommage que tu n'ai pas partagé tes mix avec ton thème.
    avec d'autres mix le rendu n'ai pas le même.
  • **I don't know why but when I select this theme, the start button menu words change into blocks and lines.
    Any suggestions??
    the start button menu words change into blocks and lines.**
  • @supermagicom there is problem between the theme itself and the main readme. In anyway, you have to keep the same license and credit the recalbox team. It's regarding modifications that there is a confusion. Any way, any edit is welcome on gitlab.
  • Themer
    @toto421 Salut toto, les mix d'images ne sont pas disponible pour l'instant car il y a un problème de copyright et je dois éditer chaque mix un à un. Donc dès que j'aurai une minute je modifierai le lien et ajouterai les mix pour UXS. Désolé du délais je comprend la déception.
    @rick-serrano said in [Theme] Clean Retro:
    Any suggestions??
    Try changing the language to English. There's a known issue about this and should be fixed in the next RB update.
  • Best theme in my opinion!!! Congratulations
    On SNES system, i try the EU version, console on main menu looks ok, but the gamepad on the top of the screen is appearing with the US version. Can you fix it?
    Thanks!
  • Themer
    @makination said in [Theme] Clean Retro:
    Thanks!
    Hi makination,
    It's a known issue. When importing the svg in Photoshop the buttons of the EU controller dissapear. I didn't found a way. We currently are replacing all controller SVG on this theme and this should fix the issue 🙂
78.1k
19.9k
146.5k
