<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[RetroTINK-Ultimates no image]]></title><description><![CDATA[<p dir="auto">So I bought this hat to output to vga and use some custom hdmi_timings. But I just can't get an image. At all.</p>
<p dir="auto">I use the configuration file found here <a href="http://eightvirtues.com/?page_id=418" rel="nofollow ugc">http://eightvirtues.com/?page_id=418</a> but I guess that was not made with vga in mind.</p>
]]></description><link>https://forum.recalbox.com/topic/12588/retrotink-ultimates-no-image</link><generator>RSS for Node</generator><lastBuildDate>Wed, 13 May 2026 00:20:44 GMT</lastBuildDate><atom:link href="https://forum.recalbox.com/topic/12588.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 03 Feb 2018 07:10:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to RetroTINK-Ultimates no image on Sun, 04 Feb 2018 12:19:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.recalbox.com/uid/21875">@mr-karmeck</a> the sh are made for retropie, it's gonna need quite some customisations to make them work on recalbox. If you're fine with linux, then go ahead. If not, i don't have time to spend on that.</p>
<p dir="auto">Note that hisresolution.ini is for mame 0.184, which has quite soe differences with  mame 0.78 (and probably mame 2010)</p>
]]></description><link>https://forum.recalbox.com/post/88796</link><guid isPermaLink="true">https://forum.recalbox.com/post/88796</guid><dc:creator><![CDATA[Substring]]></dc:creator><pubDate>Sun, 04 Feb 2018 12:19:05 GMT</pubDate></item><item><title><![CDATA[Reply to RetroTINK-Ultimates no image on Sun, 04 Feb 2018 10:42:31 GMT]]></title><description><![CDATA[<p dir="auto">And we have progress. Mike Chi mailed me back with a working config file. Now hdmi timings it came with  was out of range for me so I used</p>
<p dir="auto">hdmi_timings=2048 1 180 202 300 240 1 3 5 14 0 0 0 120 0 85909090 1</p>
<p dir="auto">From his website.</p>
<p dir="auto">Now I have thees sh files found here <a href="https://drive.google.com/drive/folders/0B8uZtHByEHyBMkNRRmk4T2E1ZUk" rel="nofollow ugc">https://drive.google.com/drive/folders/0B8uZtHByEHyBMkNRRmk4T2E1ZUk</a> to make emulation not stretch so much. Were do I put them to have the same effect as with retropie.<br />
hdmi_timings=450 1 50 30 90 270 1 1 1 30 0 0 0 50 0 9600000 1<br />
display_rotate=0</p>
<p dir="auto">audio_pwm_mode=2<br />
disable_audio_dither=1</p>
<p dir="auto">disable_overscan=1</p>
<p dir="auto">hdmi_drive=2</p>
<p dir="auto">config_hdmi_boost=0</p>
<p dir="auto">hdmi_force_hotplug=1</p>
<p dir="auto">boot_delay=3</p>
<p dir="auto">disable_splash=1</p>
<h1>Overclock</h1>
<p dir="auto">gpu_mem_256=128<br />
gpu_mem_512=256<br />
gpu_mem_1024=512</p>
<p dir="auto">avoid_safe_mode=1</p>
<p dir="auto">dtoverlay=pi3-disable-bt-overlay</p>
<p dir="auto">dtparam=audio=on<br />
#dtoverlay=pwm-2chan,pin=18,func=2,pin2=19,func2=2</p>
<p dir="auto">dtoverlay=dpi24<br />
enable_dpi_lcd=1<br />
display_default_lcd=1<br />
dpi_output_format=519<br />
dpi_group=2<br />
dpi_mode=87</p>
<p dir="auto">kernel=zImage<br />
overscan_scale=0<br />
�����������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������</p>
]]></description><link>https://forum.recalbox.com/post/88788</link><guid isPermaLink="true">https://forum.recalbox.com/post/88788</guid><dc:creator><![CDATA[MR Karmeck]]></dc:creator><pubDate>Sun, 04 Feb 2018 10:42:31 GMT</pubDate></item><item><title><![CDATA[Reply to RetroTINK-Ultimates no image on Sat, 03 Feb 2018 10:43:27 GMT]]></title><description><![CDATA[<p dir="auto">Using the lakka img I do get image, 120hz 240p also working. So nothing wrong on the hardware side.</p>
]]></description><link>https://forum.recalbox.com/post/88673</link><guid isPermaLink="true">https://forum.recalbox.com/post/88673</guid><dc:creator><![CDATA[MR Karmeck]]></dc:creator><pubDate>Sat, 03 Feb 2018 10:43:27 GMT</pubDate></item><item><title><![CDATA[Reply to RetroTINK-Ultimates no image on Sat, 03 Feb 2018 10:08:28 GMT]]></title><description><![CDATA[<p dir="auto">I'm now trying the pre made lakka img to know everything is working.</p>
]]></description><link>https://forum.recalbox.com/post/88669</link><guid isPermaLink="true">https://forum.recalbox.com/post/88669</guid><dc:creator><![CDATA[MR Karmeck]]></dc:creator><pubDate>Sat, 03 Feb 2018 10:08:28 GMT</pubDate></item><item><title><![CDATA[Reply to RetroTINK-Ultimates no image on Sat, 03 Feb 2018 09:59:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.recalbox.com/uid/1056">@substring</a></p>
<p dir="auto">I use overlays for scanlines? But I guess you're meant somthing else.</p>
<p dir="auto">I have now tried without hdmi timings. I also tried dpi_group 2 and dpi_mode 4 to no success.</p>
<p dir="auto">No image whatsoever. My crt monitor does notice when I plugg the vga in and out.</p>
]]></description><link>https://forum.recalbox.com/post/88667</link><guid isPermaLink="true">https://forum.recalbox.com/post/88667</guid><dc:creator><![CDATA[MR Karmeck]]></dc:creator><pubDate>Sat, 03 Feb 2018 09:59:38 GMT</pubDate></item><item><title><![CDATA[Reply to RetroTINK-Ultimates no image on Sat, 03 Feb 2018 09:49:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.recalbox.com/uid/21875">@mr-karmeck</a> does ut need a particular overlay ?</p>
]]></description><link>https://forum.recalbox.com/post/88663</link><guid isPermaLink="true">https://forum.recalbox.com/post/88663</guid><dc:creator><![CDATA[Substring]]></dc:creator><pubDate>Sat, 03 Feb 2018 09:49:34 GMT</pubDate></item><item><title><![CDATA[Reply to RetroTINK-Ultimates no image on Sat, 03 Feb 2018 09:06:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.recalbox.com/uid/1056">@substring</a> I do not, no image. I'm yet to test without any hdmi_timings though, will test to use only dpi_group=2 dpi_mode=87 when I get home.</p>
]]></description><link>https://forum.recalbox.com/post/88655</link><guid isPermaLink="true">https://forum.recalbox.com/post/88655</guid><dc:creator><![CDATA[MR Karmeck]]></dc:creator><pubDate>Sat, 03 Feb 2018 09:06:22 GMT</pubDate></item><item><title><![CDATA[Reply to RetroTINK-Ultimates no image on Sat, 03 Feb 2018 08:39:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.recalbox.com/uid/21875">@mr-karmeck</a> the settings are for retroarch mostly, but you must edit your config.txt first of all. Have you done so ? Do you see emulationstation at least ?</p>
]]></description><link>https://forum.recalbox.com/post/88652</link><guid isPermaLink="true">https://forum.recalbox.com/post/88652</guid><dc:creator><![CDATA[Substring]]></dc:creator><pubDate>Sat, 03 Feb 2018 08:39:11 GMT</pubDate></item></channel></rss>
