<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Solved][GBA] Cant make Pokemon Ruby&#x2F;Sapphire run]]></title><description><![CDATA[<p dir="auto">Hello Guys, first of all I would like to say thanks to the creators of recalbox, its a great project and I love to use it!   Unfortunatly I did not find a solution for my problem myself. Yesterday I was trying to play Pokemon Sapphire for GBA, but when I start the rom, it returned to recalbox after a while. I already included the gba_bios.bin file and other games like sonic work on the GBA emulator. Only Pokemon Sapphire and Rubin doesnt work. In another thread I found out that it could have something to do with a game_config.txt file, but I don't know where I should put this file, I already tried to put it in \RECALBOX\System and \RECALBOX\gameboyadvance but it did not work. I would love to play Pokemon since my GBA does not work anymore, could someone help me?</p>
]]></description><link>https://forum.recalbox.com/topic/1124/solved-gba-cant-make-pokemon-ruby-sapphire-run</link><generator>RSS for Node</generator><lastBuildDate>Thu, 23 Apr 2026 03:48:03 GMT</lastBuildDate><atom:link href="https://forum.recalbox.com/topic/1124.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 19 Aug 2015 11:20:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [Solved][GBA] Cant make Pokemon Ruby&#x2F;Sapphire run on Sun, 21 Feb 2016 14:03:50 GMT]]></title><description><![CDATA[<p dir="auto">Hi, first, i got my soms from <strong>edit no download links</strong> at first try pokemon ruby ,saphire ,emerald dit niot work at all. then i found out if you start any GBA game perhaps ruby and befor it runs you press very fast the "+" and "B" key this wil take you to a menu where you select an Emulator and select GPSP!! it wil run but the controls are messed up so i recomend watching this video <a href="https://www.youtube.com/watch?v=eM9BB9v9288" rel="nofollow ugc">https://www.youtube.com/watch?v=eM9BB9v9288</a></p>
]]></description><link>https://forum.recalbox.com/post/16305</link><guid isPermaLink="true">https://forum.recalbox.com/post/16305</guid><dc:creator><![CDATA[jordy-robignon]]></dc:creator><pubDate>Sun, 21 Feb 2016 14:03:50 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved][GBA] Cant make Pokemon Ruby&#x2F;Sapphire run on Sat, 13 Feb 2016 21:27:47 GMT]]></title><description><![CDATA[<p dir="auto">hello.. I had the same issues with different Pokemon version and after adding <code>gba.core=mgba</code> to the config I could finally play all Pokemon games, however the new emulator/core is awfully slow... is there any way to fix that?</p>
]]></description><link>https://forum.recalbox.com/post/16091</link><guid isPermaLink="true">https://forum.recalbox.com/post/16091</guid><dc:creator><![CDATA[anima]]></dc:creator><pubDate>Sat, 13 Feb 2016 21:27:47 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved][GBA] Cant make Pokemon Ruby&#x2F;Sapphire run on Sun, 23 Aug 2015 13:21:02 GMT]]></title><description><![CDATA[<p dir="auto">on the 3.3.0 bêta we added a new gba core to run pokemons games. So you have juste to edit the recalbox.conf file, and add anywhere : <code>gba.core=mgba</code> The recalbox will switch on this core, and your game start normally.</p>
]]></description><link>https://forum.recalbox.com/post/9886</link><guid isPermaLink="true">https://forum.recalbox.com/post/9886</guid><dc:creator><![CDATA[rockaddicted]]></dc:creator><pubDate>Sun, 23 Aug 2015 13:21:02 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved][GBA] Cant make Pokemon Ruby&#x2F;Sapphire run on Wed, 19 Aug 2015 19:15:23 GMT]]></title><description><![CDATA[<p dir="auto">You are welcome.</p>
]]></description><link>https://forum.recalbox.com/post/9787</link><guid isPermaLink="true">https://forum.recalbox.com/post/9787</guid><dc:creator><![CDATA[rockaddicted]]></dc:creator><pubDate>Wed, 19 Aug 2015 19:15:23 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved][GBA] Cant make Pokemon Ruby&#x2F;Sapphire run on Wed, 19 Aug 2015 19:03:10 GMT]]></title><description><![CDATA[<p dir="auto">Oh my god it works!! thank you rockaddiced! You just rescued my girlfriends birthday <img src="https://forum.recalbox.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=qq7v1sdgudo" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" title=":)" alt="🙂" /> works perfectly!</p>
]]></description><link>https://forum.recalbox.com/post/9786</link><guid isPermaLink="true">https://forum.recalbox.com/post/9786</guid><dc:creator><![CDATA[sascha]]></dc:creator><pubDate>Wed, 19 Aug 2015 19:03:10 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved][GBA] Cant make Pokemon Ruby&#x2F;Sapphire run on Wed, 19 Aug 2015 17:50:57 GMT]]></title><description><![CDATA[<p dir="auto">Hello, yes indeed there is a problem with pokemon games and this emulator. But the problem don't come from recalbox, but from the retroarch core used. So if you want play to your pokemon games, there is a tricks. Start any gba game, once the game booted, press hotkey + B to open the retroarch options menu. There, go to <code>Load Content</code>, then <code>Select File</code>. Now go to your gba's roms folder and select your game <code>/recalbox/share/roms/gba/your_pokemon_game.gba</code> The game should start. The next time you would like to play to this game, start any gba game, go to retroarch menu option and this time go to <code>Load Recent</code> and select your game in the historical. And when you want to save your pokemon games, don't use the in game save, but the savestates (hotkey + X/Y).</p>
]]></description><link>https://forum.recalbox.com/post/9783</link><guid isPermaLink="true">https://forum.recalbox.com/post/9783</guid><dc:creator><![CDATA[rockaddicted]]></dc:creator><pubDate>Wed, 19 Aug 2015 17:50:57 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved][GBA] Cant make Pokemon Ruby&#x2F;Sapphire run on Wed, 19 Aug 2015 17:06:50 GMT]]></title><description><![CDATA[<p dir="auto">Mhmhm looks like the standard recalbox gba emulator has some probs with pokemon games. With this tut you can easily add another gba emulator. Its a French tut but thanks to google it's understandable: <a href="https://translate.google.de/translate?hl=de&amp;sl=fr&amp;tl=en&amp;u=http%3A%2F%2Fblog.recalbox.com%2Fforums%2Ftopic%2Ftutogba-utiliser-gpsp-ou-retroarchgpsp-libretro%2F" rel="nofollow ugc">https://translate.google.de/translate?hl=de&amp;sl=fr&amp;tl=en&amp;u=http%3A%2F%2Fblog.recalbox.com%2Fforums%2Ftopic%2Ftutogba-utiliser-gpsp-ou-retroarchgpsp-libretro%2F</a></p>
]]></description><link>https://forum.recalbox.com/post/9782</link><guid isPermaLink="true">https://forum.recalbox.com/post/9782</guid><dc:creator><![CDATA[seic]]></dc:creator><pubDate>Wed, 19 Aug 2015 17:06:50 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved][GBA] Cant make Pokemon Ruby&#x2F;Sapphire run on Wed, 19 Aug 2015 13:44:17 GMT]]></title><description><![CDATA[<p dir="auto">Hmm, I tried it with a german and a USA rom, but it does not work here are some screenshots: Any idea? <img src="http://fs1.directupload.net/images/150819/9x3ktv5b.png" alt class=" img-responsive img-markdown" /> <img src="http://www.directupload.net/file/d/4084/9zzifjjo_png.htm" alt class=" img-responsive img-markdown" /><img src="http://fs1.directupload.net/images/150819/9zzifjjo.png" alt class=" img-responsive img-markdown" /></p>
]]></description><link>https://forum.recalbox.com/post/9778</link><guid isPermaLink="true">https://forum.recalbox.com/post/9778</guid><dc:creator><![CDATA[sascha]]></dc:creator><pubDate>Wed, 19 Aug 2015 13:44:17 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved][GBA] Cant make Pokemon Ruby&#x2F;Sapphire run on Wed, 19 Aug 2015 12:50:39 GMT]]></title><description><![CDATA[<p dir="auto">It should work when you put the "game_config.txt" from github intro "/recalbox/share/roms/gba/". And don't forget the name of the rom must be identical with the name inside the game_config.txt. "Pokemon Sapphire.gba", [no]   "Pokemon Sapphire (U) [!].gba", [yes]</p>
]]></description><link>https://forum.recalbox.com/post/9776</link><guid isPermaLink="true">https://forum.recalbox.com/post/9776</guid><dc:creator><![CDATA[seic]]></dc:creator><pubDate>Wed, 19 Aug 2015 12:50:39 GMT</pubDate></item></channel></rss>
